Ian S
You'll need:
• Head gasket set. I'd get the Fiat one next time. I got the FAI and the rocker gasket leaks. I wasn't sure the head gasket was going to align with the holes. The coil pack end seal was the too small and I had to go and buy the Fiat one.
• Cam shaft seal if it's not included in the head set.
• Head bolts. Again, get decent ones. One of my new ones stretched before full torque to Haynes manual spec. was reached it felt about to snap. I've snapped weak head bolts before torquing down high boost 5GTT heads extra tight.
• Maybe the cam belt, inspect yours and decide then or go by the mileage it's done.
• Shims. That a bit of a tricky one as you don't what what thickness's until you're doing it. I borrowed a box full from a garage for a few days and fortunately it contained all the exact sizes. http://www.ebay.co.uk/itm/291385564097?_trksid=p2060353.m1438.l2649&var=590497917827&ssPageName=STRK%3AMEBIDX%3AIT
• New coolant.
• Maybe some specific socket spanners and extensions. There are a some hard to get to nuts, one or two on the back of the manifold.
• The right pliers or grips or pry tool to get the shims out or the buckets.
• Micrometer or digital or dial calliper to measure the shim thickness.
• Feeler gauge to measure the shim to cam gap.
• Assembly oil. I used some engine oil.
• Cleaning materials, brushes to clean out the oils ways, etc.
• Maybe a head skim. Make sure the swarf is removed from the front oil way before you put the head back on the car.
• Small torque wrench.
• The means to hold the cam or head while changing the sprocket if you need to, ie, big bench vice with soft jaws, etc.
• Haynes manual.
• Patience and time. Especially with getting that arch liner back on.
I put the car on a stand, the trolley jack under a wood block under the sump and took off the drivers side engine mount so I could move the engine up and down to get access to the various bolts, etc.
The 866 is maybe 1mm taller but it's the gap between shim and the back you measure to, not to the lobe tip. You fit the shims, turn the car a couple of trime to settle them in the oil in the buckets, then measure them all and write that down. Calculate what the error is and therefore what new thickness you need so as to achieve the correct gap. Go and get them. Fit them. Measure again. Get some more if they were not quite right.
• New coolant.
• Haynes manual.
