Thanks for the advice yes done it today pretty easy to be fair with all the right tools only thing is when I finished the car started no worries but no power steering all I've done is cambelt water pump and tensioner any ideas?Check the guides section for 1.2 Fire Punto EVO cambelt change and there you find all the info you need. 8 valve or 16 valve? Turbo or non-turbo?
This is pretty common question, so please do some research. Do you have all of the tools, engine timing & locking tools? If not, then consider that it is relatively cheap to get it done at the garage professionally and it's still quite a new car. You know the risks involved.
If you have done these before and it is 8v version, then it should not be impossible. Yes silicon gasket sealant is used for the water pump. Permatex grey should be ok. Take into account that it needs to dry too. Get the correct timing &lock tools for the engine too. It's also pretty easy to do it wrong without the locking tools and it'll end up costing more than you could imagine.Good luck.
I would guess you’ve caught a wire/ connector somewhereThanks for the advice yes done it today pretty easy to be fair with all the right tools only thing is when I finished the car started no worries but no power steering all I've done is cambelt water pump and tensioner any ideas?
Would it be the wires in the belt coverI would guess you’ve caught a wire/ connector somewhere
Yes changed fan belt that has an automatic tensioner so all good battery all good alternator all good only wires I've touched are the ones that run in cambelt coverI think the wire on the belt cover runs to the crankshaft position sensor and the oil pressure switch.
How's the accessory belt? Did you change it, also the automatic tensioner needs changing just to be on the safe side. How many miles on clock? How about accessory belt being a little loose!?
Measure the charging current for idle and revs from battery terminals. How much does it fluctuate? Optimal voltage should be about 13.5-14.2 volts. A cigarette lighter voltage meter is also very handy. I usually have it on constantly and check it a few times while driving. Luckily my Linea is not so prone to alternator faults because it still had hydraulic power steering. Tipo also appears to have a very spacious engine bay. Perfect for diy guys.![]()
You didn't remove the rocker cover to lock the camshaft? The faster way to do it is to open the main ECU connectors, but i've never done that. Of course if ECU is not bolted on the cover on Tipo, then I'm just talking nonsense. Usually Fiat design doesn't change much over the years. It can't be the wires on the cover, because it would cause the engine not to start at all.
How's the charging voltage? Good? The problem started after the cambelt job so probably nothing's wrong with the alternator either, so first suspect is the belt that runs the alternator and its tightness. Multiecuscan might be able to tell more details on why epas is not available.
charging voltage is good yes changed cambelt water pump and tensioner car starts as it should turn ignition on and all electrics work ie electric windows heater fan etc soon as you start the car nothing works im at a lose any ideasYou didn't remove the rocker cover to lock the camshaft? The faster way to do it is to open the main ECU connectors, but i've never done that. Of course if ECU is not bolted on the cover on Tipo, then I'm just talking nonsense. Usually Fiat design doesn't change much over the years. It can't be the wires on the cover, because it would cause the engine not to start at all.
