If you slacken off the pulleys, it allows you to tension the belt to full tension, you can then return to TDC, tighten the pulleys, turn the engine over two full revolutions, slacken the tensioner to the correct tension and turn the engine over again and check the cam lock tool positioning. It's essential to bed the belt in correctly.
