Brin's OEM Astra Twinport
hi all,
thought id make a thread about me new astra although it proberly isnt going to get modded...yet ;) haha
only had it couple of weeks tis a nice solid car nice to cruise in :)
Spec:
Vauxhall Astra
MK5 SXI 3Door Sports Hatch (Astra H)
2006
1.6 16v Twinport
Metallic Black
my 2 cars (punto and astra :D )
cheers
brin :)
Status
Not open for further replies.
decided to use standard top half of inlet as I don't have no money have to maintain the car needs all new suspension :( maybe at a later date I will finish my inlet :( bottom half is the flap removed and port polished half though :)
Stripped! took me 3.5hours to strip it in total as every single nut and bolt was siezed!! suprised for its age :( but i am replacing everything with stainless steel bolts and nut so never have the problem again :D
Linked the motor and sensor for twinport to the new inlet bottom half but no flaps are there the linkages is not connected to nothing but sensor and motor lol will have to see if it works , you cant map twinport from the ECU and no dealers wont do it as someone previously stated on this thread!
didnt do much today cba, was awaiting parts aswel which still havnt come :( should have test running tomorrow, then finish it all off
just bolted new head on and put timing belt back on, also fitted the bottom inlet half thats it for today
Smoothed inlet manfiold and polished it up
nah had a vac leak I sorted now buddy that's why I fouind it this morning but still rough idle :( that's only issue is the rough idle almost a misfire :(
and its £25 for RR power run on 24th feb, otherwise £50 each :)
spent the whole day, removed both inlets, cleaned them off and refitted, no luck, tried standard inlet, still no luck, alternator belt off to solver screeching noise NO LUCK!, timing belt on and off 4 time, still no luck :/ now iv swapped camshafts, buckets, carriers and pulleys and finally the screeching noise has gone, but still rough idle I dunno why :(
all the parts i had to change to sort the bent suspension!
shocker, top mount, hub, wishbone, disc, anti roll bar link, bearing/ABS sensor, alloy wheel
all is good now though all them parts were bent! now 100% aligned :)
All the little bits are now sorted, tensioner sorted!, suspension sorted, manifold flaps sorted!
on road now and b*tches be lookin at me like "sh*****t son!! this kids got it going on!!" ;) aha
https://www.youtube.com/watch?v=CD8FinVQMds
few days old the vid but never got round to uploading lol...fitted new tensioner and misfiring stopped! was a broken tensioner not holding the belt tight properly
all sorted!! on the road atm...just saving up for a full custom chromed stainless exhaust system and il make me own induction kit and then remap!!
but will have a RR graph of the head to prove it does add power for all the haters
Status
