Technical Bravo light problem
freez
1.9 Bravo 2008, front left light is not working. Right side is ok. Park and long lights works. Right side is over 13V but left side looks like only 0.7V
H1 light connector is ok. What should i look next? :(
Had similar problem few months ago. Check the ground wire inside of the headlight. It should be attached on the base where the body of the bulb is placed. Use flashlight to find it. This happened to me when I was replacing broken bulb.
Next thing is the fuse, it should be in the cabin, drivers side. Then relay, and then light switch on the stick.
Check the fuse, right and left are not on the same fuse (so in the eventuality you have a short-circuit on one light you still have the other to get you home safe)
Having same issues with my right headlight. Same voltage on wires inside of the headlight 0,7V as the author. All of my fuses are checked inside the car and inside the engine compartment. Last year I have been repairing wires in left light and I have thought it was that in right lamp too but, this time I bought new set of headlights (left and right, black, for Croma) and still the right one is not working, only the low beam light. There rest ones are working properly. Had someone had similar issues? Maybe some relay somewhere?
