Hello guys I’m a new owner of fiat bravo 1.4 turbo 150 hp and I have one electric problem in my dash appear 2 light red and yellow of the airbags and my kilometres is on and off did someone know what happened?
Blinking mileage means proxi alignment is needed. It means that the car detected a loss / change in the electronic modules connected to the CAN network.
They are several modules, as nowadays cars are rather computers on wheels. Body, engine, ABS, airbag, instrument cluster, radio, etc. As the airbag lights are on, I assume it is an airbag module error. Might be expensive...
What happened prior to those symptoms (blinking mileage and airbag lights on)?
First thing you should do is connect the car to a FIAT dedicated scanner. Most of us use MultiEcuScan or AlfaOBD. That shall allow you to find a direction where the error might be located.
