Hi all
Just joined hoping you can help with a problem on a friends Fiat Brava. Its an 80 sx 1.2 manual, no aircon, model year 2001.
She took it to a local garage a couple of weeks ago, as it wouldn't start very well, and it ran badly. Also the temperature gauge was flicking up and down.
Garage found error codes P0115 and P0340, and had to refill the radiator
They replaced the cam sensor, and the temperature sensor (brass fitting near thermostatic valve). However, on road testing, the error codes are still present. They gave the car back to her, saying it needed to go to Fiat to be properly diagnosed on a fiat machine...
So, my OBD scanner confirms the 2 error codes. It also shows a coolant temperature of minus 40 degrees. If I take the plug off the sensor and short 2 of the wires, the coolant temp shows positive 266 degrees. I'd say the sensor was duff, but its just been replaced.
The engine starts and runs ok. It warms up fine, and the radiator hoses are all hot to the touch. The internal heater delivers hot air.
The dashboard gauge needle goes to the half way position, which seems ok, but then begins to flicker up and down slightly, which isn't ok.
The radiator fan is on all the time even when the engine is cold. This is wrong but I can't find a separate switch or sensor for this. Is it controlled by the ecu?
Removing the fuse allows the engine to warm up correctly.
I had to clean up fouled plugs and throttle body, but I guess the engine is running rich due to the ECU using its default settings instead of receiving an accurate water temp reading.
My apologies for a rambling post. Hopefully there's enough here for you to diagnose something.
Many thanks for your time and expertise.
