Imagine you drilled a tiny hole in your brake pipe. If you pressed your brake it would work fine to begin with and then slowly the peddal would go down as the fluid leaked.
My panda is doing this!! The peddal slowly goes down *takes about 3 seconds) *BUT* once i let go of the brake its back where it should be again until i put pressure on it
My question: does anyone know whats causing this?? I'm desperate to fix it as i'm off to slovakia in three weeks in my car. I noticed theres a fluid pool under the bonnet thats not under pressure or anything, so logically there must be a one way valve for the fluid pool, am i right? Could it be this is letting fluid flow back into the pool?
My panda is a 1993 fire.. it doesn't have a servo.
Please help me.. mrooo
