Bushboy said:plus its bloody quick enough as it is without silly valves
first off, what u on about, a car can never be quick enough!!
i personally run in can adjustable boost (bleed valve) and have never had any probs with it. as aaron says, it is classed as a crude mod as it does trick the wastegate(actuator) into staying closed and allowing more boost.
i also run a FSE fuel regulator as well as an uprated fuel pump. i have to run these as my car would other wise run lean causing melted pistons etc (as jamie found out).
my UT was set up on a rolling road and the fuel was adjusted to match the boost, there fore i dont ever mess with the in car bleed valve as i dont want to mess it up and its all set perfectly.
taking off the bleed valve "should" in theroy make the car run the same boost as if u locked the bleed vlave off. and that boost will be whatever the actuator has be set at. u can adjust the actuator by winding the thread in and out depending on if u want it to allow more boost or less boost before opening.
one thing i dont reccomend, but always creases me, is lock the bleed valve off, floor it in like 3rd and wind the boost up while u booting it, lol, u can really feel the difference lol (Dunc is not responsible for any mis haps if u do this tho!)
mk1 and mk2 both have boost guages as standard!
Dunc
