tobywood13
Hi all, my ‘93 Panda is displaying the battery warning light. It appears a few seconds after start up, and remains visible while driving at various speeds and RPMs. Interestingly, yesterday I took it out for a drive and the headlights were very dim, but when I did a hard pull they suddenly got quite bright and then remained bright for the rest of the drive, as if the alternator suddenly generated a burst of charge. I’ve replaced the alternator belt, but that doesn’t seem to have made a difference.
When I bought the car I drove it two hours home with this light on the whole time, and it survived the trip. When running the battery measures about 11.5 volts, so it’s just barely below remaining neutral but far from the approx 14v it should be at. I’ve done around 200 miles since I got the car, and it has had the light on the entire time but the battery has not died yet. It starts up easily every time.
What might be the cause of this low charging? Is it a bad alternator, or a parasitic drain somewhere perhaps? Basically, what things can I check before I go and buy a replacement alternator. Thanks!
- Model
- CLX 1.0
- Year
- 1993
