Technical Battery Terminal Connection Loose - It is secured by a plastic lever
HayBob
United Kingdom
Hi All - I am hoping you can assist. On my X250 year 2014, the negative battery clamp is loose. It is not secured by a bolt which can be tightened. It has a plastic lever which clamps the metal fitting to the battery post. I can not see how the lever can be adjusted so its grips tighter. Can you please advise if it is a common problem and what is the best way to fix it.
Hi, Thanks for the replies. The positive has a nut to tighten - that works well. The negative clamp is closed by a plastic lever. The terminal are a standard size. The lever action is like a bike road wheel but there is no thread to tighten or loosen as per a bike road wheel.
Cheers
Cheers
Is the clamp right at the bottom of the conical terminal post? I think that the lever clamp is an OEM fitting on many Fiat vehicles. Certainly my 2006 x244 has this type of clamp. I have considered the possibility of the problem arising, but did not come up with a simple fix. Obviously changing the clamp is possible, but then the convenience of the lever action is lost.
Hi, could I suggest a piece of copper pipe cut to size. If too tight put a slit down the length of it and expand a little. If too loose make a wider slit to allow it to be clamped tight. Hope this makes sense. Ian.
Using a spare Panda battery to test house elctricity continuity, I have noticed that teh positive and negative terminals are slightly different sizes. Each has a platic cap and one is bigger than the other. I have previously used additional lead sheet to close a gap in such circumstances. The metal end of the clamping bolt surely screws on so some adjustment can be had by turning it. If you have to get the clamp off the terminal rail to accom[plish this then its a lot of work to do. Half a turn will be more than enough. If you cannot turn the plastic end then the other end must turn.
Yes, it's a standard for all batteries to prevent accidental reverse connection.
Yes, it has some adjustment, in my case it was already at the end.
It took me like 10 minutes to bring the thing home, unscrew it, grind the surfaces and put a washer on the other side. It was just worn out, and the battery was replaced a few months earlier, so I knew it was not the problem of the lead battery terminal (which is definitely softer than the clamp).
Im not very bright never noticed before in quite a long time....
Hi all great advice. Its a brand new battery. Euro parts and others sell battery shims which can slip over the terminal. I will file/grind between the clamp so it is tighter. Also as mentioned the lower the clamp goes down the tighter it gets.
Thanks all for helping me overcome the problem.
