anyone with virgin media?
In a house
we don't have a land line phone and in so, i have no idea how much it will cost to phone em from my mobile
http://shop.virginmedia.com/phone/calling-costs.html
so no idea theire
basically
Network Configuration
WAN IP Address
Duration D: 03 H: 23 M: 41 S: 09
Expires Sun May 22 13:52:44 2011
WAN Subnet Mask
WAN Default Gateway
WAN Primary DNS
WAN Secondary DNS
keeps blanking out.
the duration decreases tho
probably gone at least 10 times today (while i have been on)
this is the log from last 2 days. anything seem a little erm well logged?
I have sent them an email to the only address i could find as a complaint.
any ideas?
it had gone about 10 mins before this post about 10 past
We have virgin media - it keeps crapping out also:(
Tv keeps going, internet used to keep going - after the 11th time we said we would leave if it happens again - happened once more, we never switched but it's not gone since - 1 month almost since then
Tv still goes down DAILY, EVERY DAY:mad:
our tv works.
found another log
http://img109.imageshack.us/img109/4103/vm2c.png
that forum is a pile of ****,
Ill wait the decade for the email i have sent to complaints to be routed to the proper place.
to me its a line fault not a modem fault.
reading out bill the land lord leaves in the flat £1.25 for a paper bill
15 of these errors today if its anything to do with it.
Thu May 19 10:49:01 2011 Critical (3) DHCP FAILED - Requested Info not supported.
Thu May 19 10:48:49 2011 Critical (3) No Ranging Response received - T3 time-out
yep current system time is 1 hour out
so pc is now set to 192.168.0.9 router is 192.168.0.1 = gateway
and dns as said.
just to wait and see if it does it again.
ill set same on laptop, and tell other flat mates do do same as well?
obviously changing static ip of each pc
last time it did it was
Fri May 20 08:25:44 2011 Critical (3) DHCP FAILED - Requested Info not supported.
Fri May 20 08:25:34 2011 Critical (3) No Ranging Response received - T3 time-out
Fri May 20 08:24:54 2011 Critical (3) Unicast Ranging Received Abort Response - Re- initializing MAC
my pc wasn't even turned on, could it be a phone on wifi or something like that causing it?
or even a psp, which was one of the latest additions to the net work
shame the log, hasn't logged devices on at the time
It's nothing to do with unauthorised access. It's someone who already has your key and is on your LAN.
OR the error relates to the DHCP client on the Modem for the connection to Virgin (WAN).
Have you read this:-
http://community.virginmedia.com/t5...ing-Response-received-T3-time-out/td-p/225563
According to a guy in that thread it was resolved on their end.
VirginForum Guy said:
Hi GarryEHunt,
I have checked your connection and have identified a local upstream utilisation issue on your UBR (local router) which will cause your speed to slow during busy periods. I have passed this to our network teams to resolve, we're sorry for any inconvenience caused.
Regards,
Rose Rafferty
Help & Support Forum Team
