Ahh bugger, missed out the =uk bit, at least it works now
For some strange reason that didn't work either. I eventually found a list of BB codes though. It was supposed to be {fuelly=uk}value{/fuelly} swapping { for [
And just passed half a tank so not long 'till the next fill
I can see your point but I don't even think it would effect that. Only effect I'd see them doing is causing the car to be slightly heavier
Anymore results yet sludgeguts?
True! I agree too. Pity my wallet doesn't share our views though.That's ridiculous.
True! I agree too. Pity my wallet doesn't share our views though.![]()
To be honest with you, absolutely no repairs had been effected on the car just before I put on these magnets whatsoever. In addition, the weather parameter cannot come into the equation either, because throughout autumn and now in the winter the weather over here has been pretty stable with temperatures ranging from 5C to 20C. The only snow we've seen so far here was a little sleet for only a couple of days which - of course - is a joke compared to what you've been experiencing over there recently.....You didn't put them on shortly after fixing / servicing / putting more air your car did you?![]()
That's probably a fair point but consumption should be consistent over same run, same weather, same level of congestion and of course the same driver.My point is you can easily influence the mpg. The only true test is if you didn't know if the device was fitted or not.
Second that!....I actually did two identical town runs like this and was amazed that I got 50.1 mpg returned for both journeys (about 5 miles each using trip 'B')
