Technical Any recommendations on someone who can rebuild a synchro nani gearbox?
Abarth 695
Nottingham
I have a Giardiniera and have bought a 126 gearbox, nani 5th gear kit and I am looking for someone with the know how to re assemble everything correctly within tolerances so there is minimal noises. Any recommendation appreciated.
Model
Fiat Giardiniera
Year
1967
Try contacting Andrew Harvey---he fitted a 5th speed to HIS gearbox I do have his e-mail address, but I don't think that I am allowed to put this sort of info on the Forum, so if you would like to contact me direct ( [email protected] ) I will pass it on to you. I am going away for 3 days as of tomorrow morning, so if I don't answer your e-mail for a few days. don't despair. Be aware,the 5th speed "add-on", must onlybe regarded as a 'cruising' gear and not an 'accelerating' gear---the shaft that the gear runs on is only supported (on nearly all the conversions) at one end. The gear-change selection 'gate' has to be modified, and there is a "u-tube" film showing how to do this---I will happily pass this info onto you as well. The gear-change 'lollypop' has to be shortened---I also have this measurement to hand.
