Technical Am I in limp mode? Wont rev above 2700rpm
olNick
Hi all,
Wife's Qubo, MJII, 95HP, 2012? wont rev above ~2700 rpm when the shifter is any gear.
Revs fine when gear lever is in neutral.
Car cant climb even the slightest incline.
Did this first time 2 weeks ago and somehow cleared itself up and normal.
Added injector cleaner a filled the tank, which was almost empty.
Did it again last night as I say above, and the same today. Car is undriveable.
Am I in limp mode, and if so how do I get out of it.
Any ideas? I read various post but nothing definitive.
thank you,
Nick
Went to the garage and we found the 2 rightside injectors leaking, pssst, pssst and an oily mess there.
There is a copper washer of sorts sealing the injectors to the head.
Seems car was running on 2 cylinders...
Wastegate ok, MAF ok, EGR ok. DPF problematic in the diagnostics.
Seriously considering bypassing it, but that's about 550 Euro, since replacing it I was quoted ~2000 Euro.
WHat do aftermarket DPF go for?
Let's see what else,
Nick
