Pete145
- Joined
- Jun 2, 2014
- Messages
- 288
- Points
- 85
Hi everyone.
Well, I've pondered this purchase for a while now (since my 595SS style of conversion), and have finally taken the plunge and ordered an aluminium valve/rocker cover (as well as the appropriate oil filler cap, gasket and gasket rings for the threads).
The top end of my engine has been oil tight for a while now, but I have had issues with leaks from the tin rocker cover not sealing (even Middle Barton Garage put her back together with a leaky rocker cover gasket). So, hopefully, a good quality, sturdy aluminium cover will be just the ticket.
After a bit of research I went for the Axel Gerstl product:
https://webshop.fiat500126.com/katalog/artikelinfo/901/abarth-aluminum-valve-cover-_vertical-letters
Does anyone have any experience doing the switch with this particular cover? I've read some previous threads that talk about the valves fouling on the inside of the cover, and also the studs not being long enough (because they're thicker). I've also heard that the breather hose sometimes doesn't fit as the (brass?) tube is thicker.
The parts arrive today, and I was hoping to tackle the job in the next day or so, any advice would be appreciated before I start!
Pete
Pete
