Technical alternative front coil springs for panda 4x4.
hello, I rode the springs of the rover 25 in my panda, and now it was higher on one side about 1cm, is it because it still has not aligned the direction?
Hi, this problem is solved, i just turn the up bearing for other position and work fine.
Now the problem was wen i run back, the wells open and still with positive camber, if I run forward it’s ok... can anyone help me?
Yes it’s the toe/out. if the front of wheels are not straight pointing in towards the front simple method is set car on a very flat surface push backwards the tyre fiction is drawing down the spring. Use a 11 mm and 20 mm spanner to adjust off the steering tie rod equally each side untill the draw down is less try this a few Times by measuring Bonnet height say 3 - 4 mtrs apart
Thanks, but i’m affraid, if I do this I lose the good alignment off the wells...
