Technical Aircon temperature sensor
Picture (what's snapped)?
Are we talking about the pressure transducer? Automatic or Manual A/C? Bypass the sensor, to do what?
On the pipe is (was) a pressure sensor. Compressor engagement should be the same anyway (Manual or Auto), so...?
https://aftersales.fiat.com/elearnsections/main.aspx?nodeID=199001427&languageID=2&markID=1&modelID=199000000&valID=199000000&prodID=199000000&modelName=Fiat - 199 - Grande Punto&langDesc=English&sectionName=Impianto Elettrico&validityName=1.2 8v
Temperature sensor is in the mirror.
Don't have pictures but its the pipe that goes into the compressor motor
And apparently there's a temperature sensor that is linked by power line to ecu and it comes up on the dash radiator temperature excessive temperature some said that because they share power source that it's messing with the ecu signals I can't regas or replace as previous owner obviously hit something with the pipe and snapped the pipe and I don't use it anyway so bypass it would hopefully solve the problem.
