S Skyperr Member Written a guide Joined Jun 4, 2008 Messages 265 Points 87 Location North County Dublin Mar 12, 2014 #1 A mates 2002 Punt has failed the test because the airbag light does not illuminate at all. It is completely dead and I doubt if the bulb / LED is the cause. I'll be looking at it tomorrow briefly, but is there a known or common cause for this?
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,187 Mar 12, 2014 #2 Light failure in the dash is rare due to failure Tampering more likely Get a code reader plugged in - see if A - it connects = Systems there B - Its registering faults C - Do the light actuatation test However if its not doing it on ignition - C isn't going to help Ziggy
PuntoHowTo That Guy off YouTube Parked in the garage Joined May 23, 2011 Messages 15,524 Points 3,714 Location Norfolk UK Mar 12, 2014 #3 I would have thought the most likely cause would be someone pulling the fuse on the airbag system to cover up the light being on. Or unplugging the airbag ecu for the same reasons
OP OP S Skyperr Member Written a guide Joined Jun 4, 2008 Messages 265 Points 87 Location North County Dublin Mar 13, 2014 #4 Thanks for the pointers. I hope to be looking at the car over the weekend and will report back on progress
oldhammer Busy rebuilding pand'a Parked in the garage Joined Oct 10, 2012 Messages 5,108 Points 1,075 Location manchester'ish' Mar 13, 2014 #5 iwouid go with what Andy has said, he knows what hes talking about on the subject of airbags, so check for missing fuse, and check for a disconected airbag ecu,
