Before I attempt a DIY refill of the air con, I decided to plug FiatECUScan in to check the presure.
0.00mb
But I also got "Air Conditioning Sensor Signal" fault.
So I used the presure gauge that came with the AC refill kit to double check the pressure manually. It was low but not Zero. So can anyone tell me where this sensor is and how to check it because I suspect the sensor is sending false info to the ECU.
0.00mb
