General Advise Needed!!!
pete1nlancs
Bacup, United Kingdom.
I have a 1992 Fiat Panda Fizz (de-fizzed) in white.
I'm thinking of spraying the bottom half of my bumpers white to match with the car. And cutting out the grille and meshing it.
I just want oppinions on how it would look??
All critisisms taken. (As long as theyre good)
Cheers Guys and Gals
Pete
K&N Induction Kit On A Panda?? Never!!!
I think it wouldn't look like the cheapest car around anymore...;)by the way don't miss to threat carefully your plastic bumpers, their surface's rough and the paint could leave it within a monthB)!I hope to find some pics of an italian boy's Panda which has been modified like you'd like to do:p
If it is "de-fizzed", can you tell us what made it a Fizz. Apart from the graphics, what else set it apart from the CLX?
Painting your bumpers is a short-term option. The surface is not smooth, so the paint wil not stick properly.
If you do it, you need to get the right stuff to clean the surface, then special primer. Available in Halfords. Don't expect good results, or for them to last.
Fiat did some special editions called Bianca, with white bumpers. The paint started to fall off after about two years.
Regrding the front grille:- i have cut round my grille leavin just the frame, painting it white and meshing behind it, it looks alot better.
