Hi does anyone know if the 1.2 8v MIA has ABS. I have tried breaking hard but don't think its hard enough as no ABS cut in and I didn't skid lol.
mia was the fred flinstone of the punto range so normally no abs, but of course an oddball order might throw one up
look for a box of bits directly behind battery sprouting brake pipes to confirm abs present or of course you could look for the symbol on startup on the dashboard
No abs is good btw, Less is sometimes Best,![]()
I Will be under the bonnet tomorrow with the steam cleaner so Will take a look, thanks
AAAAAAARRRRGGGHHHH no not good steam cleaning
too many connections / ecu you can get water in
make sure you wrap them all up well and avoid spraying on them directly
ok many will say "i do mine every spring" but how long before you start having problems with carbon tracking between pins, only thing to do then is replace units
gunk and a paint brush and rinse with watering can or hose round non electric bits
You have been warned
my owners manual says wash under bonnet every spring
mind my driving licence also tells me to split it by tearing down the dotted line but last time i did that a bobby stopped me![]()
the punto is a good braking car
If done correctly, you can cook the brakes while ripping your face off and lungs out the eye sockets
With a good brake setup tho - you should be able to get the wheels to lock up
I'd be wondering if you honestly cant, whats wrong with your brakes
Little bit of air?
Worn pads?
Make sure you not braking - then braking abit harder
Literally stamp on the brakes like your whole life depends on it
But make sure its safe to test - dont do it when a sodding bus or lorry is behind you....
Quiet empty road and test
Ziggy
I have a long week end next week so may get them off Friday before donington. It Will also be payday do if I encounter any problems I Will have the cash to sort it too. Lots of jobs on her need doing, I must make a list and prioritize it.
