Hi
I`ve heard that all 1242 cinqs run slightly hotter than the 1108
So it could be that?
Adrian
Adrian
AIJ29 said:Hi
Adrian
jamie86 said:Alex I always had it running those kindda temps and did have my concered tbh...
But has been bled loads of time the next stage was going to be that wetter water and the 'stat
custard boy said:my N/A 1108 cinq sits just under 90 usually.hoping to get a lower temp for the turbo sorted soon though![]()
fixitagaintomorrow said:The 1242 will run slightly hotter than an 1108, yep. An abarth front will also make it run hotter, as it obstructs air flow to the radiator (that's why I'm running with no foglights in).
Splash out on an oil temp gauge and see what's happening, or you could fit a cooler stat if you wanted to try that - it's a bit easier to do anyway.
Oil cooler I'd say was only really needed if you have a turbo, or on a n/asp if you cane it a lot, do lots of very high speed m'way driving, or track days. I never saw the oil over 100'c in the silver one until I went around Castle Combe.
fixitagaintomorrow said:The sender is screwed into the end of the big bolt that holds the oil pressure switch in - I just drilled and tapped the end.
If you're doing it, best get a spare bolt to try it on first - they're only a few quid.
donefingers99 said:Mods, can this be made sticky, pretty please?![]()
