4mpg, 1 mpg, make your mind up!
I've run an LPGed Stilo for 55k miles, first 25-30k using AC when it felt was needed, last 25-30k it was on constantly, night and day, regardless of if I wanted hot or cold air. In a car that returned 30-33 MPG I'm sure I'd have noticed this 4 MPG difference and you know what, I didn't as there wasn't one. Even got the stats of all 289 fill ups if you want a gander
4MPG with the compressor ON. Zero MPG with the compressor OFF. If you've got climate and the A/C is switched 'ON', the compressor might never actually turn on at all, hence a 0MPG difference. In a cold country, I can see how even leaving the switch 'ON' might not make a measurable difference, since the A/C isn't actually running. You might as well mark the switch 'Rocket Booster' or 'Free Tibet'.
While I will freely admit that 300 fill ups is impressive historical data, it's fairly meaningless unless you've also logged the exact number of hours the compressor was actually running for each fill.
Here's a little set of graphs I found:
http://mcclanahoochie.com/blog/2010/08/idle-fuel-consumption-ac-vs-no-ac/
You'll note that even turning up the fan has a marked effect on GPH. A/C almost doubles idle fuel consumption. Actual real world figures will depend on the actual compressor 'run time'.
Furthermore, your car uses almost double what my TA does, so since A/C consumption is actually measured in GPH not MPG, and MPG is only extrapolated from GPH, your MPG difference A/C on vs off should only be about half of what it is for an eco car like a TA. Perhaps it's worth pointing out that I said MY car uses 4-5MPG extra not YOUR car, nor anyone driving a Cadillac or Refrigerated truck either.
EG: Car 'A' Gets 10MPG, obviously, turning the A/C on isn't going to subtract 4MPG (maybe in a refrigerated truck)
Car 'B' gets 70MPG, turning the A/C on can easily use 4MPG.
But at idle the TA uses 0.6-0.8l/hr, and my 4.0l Jeep reports 0.7-0.9 for it's much more effective A/C, so the L/hr should be pretty similar no matter the car.
Plug in you scan tool and get back to me
