So new here but I am hoping someone has a suggestion. I have a Wildax pulsar. 2021. Auto with adblue with 2.3 lt 140 engine. In a country park lay-by I grounded on the electric side step on passenger side UK when driving over a tree trunk stub hiding beneath some leaves. I reversed off and checked. The step was a little bent but still opened and closed using the switch and a bit of manual assistance.
Then I started engine and got the following list of errors and problems
1: check engine warning light
2: check diesel fuel filter warning light
3: auto start stop not working with error light showing exclamation mark showing after the circular A
4: air con not working. Depressing the ac switch did not activate ac.
5: Fan stuck on low bit speed no longer adjustable with control dial.
The temperature can be controlled but fan speed not responding
6: reversing camera stopped working.
7: Drive mode selector near auto gearbox lever does not select any modes. Actually is doesn’t even show available modes.
8: Power steering feels heavier at low speeds
I managed to drive 250 miles home and I inserted a Bluetooth dongle for OBD2 check and error codes are
1: p0555 brake booster pressure sensor
2: p2264 water detected in fuel sensor.
I have disconnected battery in an attempt to reboot things but this has not worked.
I checked the fuel cut off switch under dashboard and that seems ok.
Van drives fine.
Any suggestions???
Van drives fine.
Any suggestions???
- Model
- Wildax Pulsar auto
- Year
- 2021
- Mileage
- 11000
