No update from
@Phil R whether he sorted his proposed spacesaver purchase and “ET20” offset query for his “normal” wheels “
ET35 offset with185x65x15”, but I notice on p152 of the February 2016 edition Owner Handbook (attached below, assuming this applies to the 2015 model), that the 185x65x15s are in fact listed as “
ET30” (it’s the “175/65 R15 84Ts” that are listed as ET35).
Also, p152 clearly states it’s the same spacesaver tyre spec for both wheel/tyre sizes (i.e. “125/80 R15 95M”) across all Panda Cross combos with no mention of differing ET values (wouldn’t the Handbook state if that was not the case?).
So I’m attaching a pic of my own 2016 4x4 “125/80 R15 95M” spacesaver which (according to the OM) will be the same and hopefully it shows all the various numbers needed to buy the correct spacesaver size (+ET value) - if not I can take another pic!
Couple of queries:
1. You’ll see that the sticker on the left is titled “312 Models” not “319” (not sure what the various numbers listed refer to) but the Mk4 seems generally to be referred to as the 319 - which is the correct designation?
2. The wheel is secured “outside up” - can it be properly secured if “turned over” so as to free up some storage space in the well? (the OH actually has a pic of this with a “tool box” fitted inside the wheel well for some models!)
Cheers
Jim
