Fattrucker
- Joined
- Aug 18, 2021
- Messages
- 11
- Points
- 53
Hi everyone .
Thank you for having me here .
First post here so sorry in advance if I do anything wrong .
And many apologies for the long post .
I have a 2015 fiat Ducato 130 Multijet low floor luton van with approximately 74K on the clock .
Engine F1AE3481D Version 250DMMCU GY
I bought it a few months ago from quite some distance away from home (250+ miles) .
On the journey home I was following the van (which was being driven by my partner) when I thought I saw the occasional puff of black smoke .
This was maybe once every 5-10 minutes or so , seemingly random and very very light .
I didn't pay this any heed as I thought it was just "Clearing itself" on a long run as I was told the van had only been used for short journeys.
The van has and does always start first time with very little cranking regardless of ambient temps and idles smoothly.
Fuel economy (according to the onboard computer- iffy I know and as a guide only) has been 42-49mpg running the vehicle without cargo .
Since I bought it I have tried to fix various minor issues with the van (cruise control not working , No temp display on the dash etc)
The van has been used maybe once a week since for the past few months but has quite quickly gotten a lot worse in regards to the black smoke issue .
Initially , under normal driving conditions the van would regularly puff a small plume of black smoke .
Almost as if on one cylinder . As the frequency of the puff increased with revs .
Now under careful slow acceleration the van has a "normal" light grey haze to the exhaust . But any attempt at quicker acceleration or acceleration under load (up a hill say)
and the van emits James Bond-esque levels of continuous thick black smoke until the accelerator is released.
As the MOT is due quite soon , as is , it's going to fail miserably on the emissions test.
Fuel economy (according to the on board computer) has fallen off a cliff and now the van struggles to do 23mpg (Again devoid of cargo and on similar routes with a similar driving style )
Stood outside with the the vehicle running and stationary the exhaust fumes sting your eyes even when they appear to be a light haze , not even thick and black .
The vehicle shows no codes when using a cheap OBDII reader (I am seriously looking at buying the MultiECUscan tool)
I have replaced the offside mirror to regain the ambient temp display on the dash (I am lead to believe from other sources that this has some bearing on how the vehicle runs with the ECU using this info ).
I have since had the DPF cleaned twice .
Replaced the MAF for a branded new branded one .
Replaced the O2/lambda sensor with a branded one (It appears to only have one-Euro5 ?)
Had the injectors flow tested (All ok "except one was a tiny bit low but all were within spec" I was told)
New turbo .
New glow plugs/heater plugs .
I hope you guys can shed some light on the subject as the last two garages were clueless .
I has been suggested that it may have something to do with the high pressure fuel pump/fuel return system ?
Sadly I am all too unfamiliar with this platform to comment on this .
P.S. Again sorry for the long post .
Fattrucker
New turbo .
Fattrucker
