Technical 2008 Ducato front suspension
Ian68
Will the front suspension units from a 2023 model fit straight into a 2008.??
Top mount looks the same just like to confirm the bottom drops into the carrier.
Opinions please..
Many thanks..
There are a lot of options when I looked. If the part numbers match, otherwise I suspect not.
Thanks for the response. It's for a motorhome where I previously changed the original set for those from a maxi chassis, gave me a bit more height in the front to level the van when parked...... Now got a cracked spring and a dicky top mount. Was guessing the basic dimensions of the strut would be the same out with the spring height and top bearing type. Anymore input appreciated..
Thanks again.
Basically it's the same van but had several faceliftings and construction changes since it was first launched. Then it's difficult to find a site that lists the part numbers for the newer models (the forum ePER has a database until 2014 more or less). But you could find the part number of the old ones (the original ones for your van) and then find these in a good online shops to check it they are being matched with the new models.
