mods from page5 translated with few words missing:
"PROCESSING ON SEICENTO
-camshafts COLOMBO_BARIANI tip: 103,280
-exhaust collector SUPERSPRINT type: 4 / 1 (+ further processed)
exhaust-pipe exhaust tip pots JOKRA SPORT: 07 s300 0 (+ further processed)
-catalyst was removed
the center-pots
OMP-type air filter: The 90mm foam O/140mm
EIBACH springs-front type: EW 3011001VA (height 270mm from the floor) 6 turns
EIBACH springs-rear type: EW3011002HA (height 280mm from the floor) 7 turns
-shock absorbers front and rear bumper type: Sport Line dimension: the slope of wheels: 0 stopin + - 2 degrees. Further Reinforced
-wheel replaced with
dirklanim OMP
replaced by pedal-OMP-
jevimi + support for the foot OMP
First-light black
signposts front-and side-black
-dismantled
meglenke
Internal-
spegu punto mk2
-External
spegli f1 karbon look
demontirano inside ....
džanje handles, rear bench, umbrella,
predalni on the doors, seat belts, luggage space policy support consoles, anti-noise protection on the cover of the engine, the thermal protection in acumulator, PVC protection of the right engine halfshaft, spare wheel, jack, tool, pvc refrigerated liquid under plastic, PVC protection against transmission, both air escape
-additional output: the water temperature, oil temperature, oil pressure
Barum tire-racing 160/530 r 13 (soon replace the other)
SCHMIDT-rim 13col 7 wide type: Modern-Line
Safety-roll bar OMP Racing srl design: + AB7106/214 further strengthened and made a set of car carriers in the interior of the cage
strutbar-OMP adjustable
-rear strut bar
Flywheel-OMP 5972 grams weight
short-
menalnik to promote
relationship have wrote:
-sleeve at the site of the steering column to lower the steering wheel
-changed kit electronics of engine (
bol nabrusen computer + without blockade)
menjan mono-anspric (frgazr)
-Reduced head
dirklane plates for brakes + changed oil to withstand higher temperatures
armaturka-alkantaro upholstered in black (even columns)
-made shelves in her key started the car + switch (also alkantara)
OMP-skolkasti seats
-4 Point H bands OMP
-padded in the rear car FILC (that is not pleha) (FILC=kind of fabric)
-ceiling upholstered in FILC
sovozniku in the air escaped ugrajen peklopni lcd screen 7ka, which is that the move towards the driver
radio JVC (dvd, dvix, etc.)
first system-DLS (morm the panels on the door nearest)
DLS-amp (morm connect)
DLS-sub (morm the box narest)
now, however, plans that will in the months of completing the:
first clean-bumper (sranske reze removed)
first-bonnet clean look bad + + from the carbon narjena
-wings of carbon will narjeni + enlarged
-adni odbijač clean (removed for the air exhauster) air exhauster will not move to the center and will be under dual DTM tablco
-on the door without handles
-free stoflca the tank (premakinen will notranost car so that the tankal back in prtlazniku)
-clean the roof (no is exactly posvasana)
uglavnm cysts clean car
-painting the car (in game one of three colors to know the will of Cyrus)
cage-doing under the car that nestovcm karterja, menalnika and podbno (they slope to the road but the car drajsa the floor)"
car's nice, wondering of 100bhp from 1.1, (from this looks like new camshaft, enginehead cut-down, new flywheel, all new SS exhaust with SS manifold and without cat con, changed/reprogrammed ECU, OMP air filter with 90x140mm, TB from punto mk2, new oil...)
but IMO rear wheels are too much too much out
how is it going on with slovenian police, will they threat you???? or you just need money for them
