- Joined
- Sep 14, 2009
- Messages
- 19,832
- Points
- 3,386
A cheap alarm on a cheap car works well if the siren is INSIDE the cabin. Anyone looking for a cheap ride home cant even sit in the thing with that blaring.
control box is connected to the sensors hazard lights and body computer.
the logical place to put it is under the dash the wiring should run down the A pillars plastic covering
• Category 1 is an electronic alarm and immobiliser. The alarm must have perimeter detection, ignition detection, passenger compartment detection and audible warning with its own power supply. The immobiliser on the other hand must be passively set (i.e. you don't have to turn it on and off like in some older cars) and must isolate at least two of the car’s operating circuits.
• Category 2 is only an electronic immobiliser, which must also adhere to the same two criteria as category 1.
• Category 2-1 is when a cat 2 car is upgraded to cat 1 after leaving the factory without an alarm. The retro fitted alarm must meet the same rules described above in cat 1.
• Category 3 is where your good old-fashioned steering wheel clamp comes in.
Sadly car alarms are of little use, unless the car owner is within earshot.
Possibly due to the prevalence of rubbish alarms in the early eighties, most people nowadays react incorrectly when an alarm goes off.
When we hear an alarm, our response should be like, "someone's property is being violated, how can I help, can I call the police, warn the offenders off, etc."
Our most likely response will be more like, "shut that b****y noise off".
I asked the Ebay seller if this alarm is Thatcham approved and this was his reply:-
Hi Bruce, yes we believe it is. This is a Factory option alarm and Fiat Pandas from 2004 were fitted with Thatcham Cat 2 Alarms.
Panda
Jan 04 - on
Code 2 Immobiliser
TE2 - 1136/0800
Regards,
Giles
D G Rally Ltd
See I’ve disagreed with this statement. If you only heard it maybe. But if you heard a smash before, or looked and saw someone half hanging out the door then I suspect most would react and call the police.
The sellers wrong that’s a dealer fit alarm.
I’ve fitted the exact same one myself to a panda. Siren should either be under the windscreen scuttle (can’t easily be ripped out to shut it up), but may be around the battery area, as needs connecting to the engine bay fuse box.
Control unit connects to the body computer. This is the lower right hand side of the steering wheel. The ultra sonic sensors should be wired to this also.
