1.2 8v VVT??
1.2 8v VVT??
I'm pretty sure the only VVT fiat engines are the 1.4l 16v but the newer one, The StarJet that came after the Panda 100HP. But that was only VVT on the exhaust cam.
The only other VVT that fiat do is the MultiAir which uses Hydralic lifters instead of cams so can have hundreds of timing combinations
Not sure they can do Variable timing on a 8v single OHC engine, since the cam do both intake and exhaust. Make the intake earlier you make the exhaust earlier (via pulley phasing) It would need to be twin lobe and that would mean cam shifting, similar to vtec, and pretty sure we would all know about it.
The Gande punto 1.4 8v has variable timing, but not sure what difference it makes
1.2 with VVT has a lkittle cylinder in top of the cam cover with 1 wire attached. This is the solenoid that activates the timing change mechanism. IIts worth removing it and cleaning as they go MUCH better when they work freely. Remove it clean with carb cleaner allow to dry. Dunk in clean engine oil before replacing.
