HI all,
hoping you guys might be able to shed some light on this issue, or throw some ideas our way?
PhilipB82 popped round today with his 5 door Stilo and we set about plugging in my laptop as I have a full registered version of MuliECUScan. Firstly, Phil has a few niggles that are proving hard to diagnose, he has the car booked in a garage in a few weeks to have the dashboard display unit tested but im not convinced its at fault - he gets an intermitted Warning light - the one dead centre in the dash, yellow triangle with a ! in the middle. This triangle seems more evident in the rain, or when its wet/cold BUT it doesn't light fully, and isn't accompanied by an error message - possibilities are Oil Level Sensor Failure, Coolant Level Sensor Failure or Oil Pressure Sensor Failure.
Phil also has some minor flat spots at certain rpm, seemingly at low revs say when at junctions setting off, or at higher revs on the motorway for example. The flat spots are not accompanied by an error light or warning.
SO, with that in mind, I hooked up my laptop and checked the codes, only one stored was for the MAF but that was an old code and the MAF has been replaced - I have cleared the code. I went through as many tests/actuator tests as I felt relevant, and everything checked out. Things like the boost solenoid valve were within parameters (40%-100%) and boost pressure the same within parameters. All actuator tests were fine, dashboard test fine (hence why I feel the dash is fine and the intermittent warning triangle is something else).
looking in the engine bay, I didn't find anything majorly obviously wrong. I did however find the air intake pipe from the front of the car into the top of the air box broken. Basically, the bend that joins the front grille is broken off, so just points into the engine bay sucking in hot air - could this be causing any issues?
I found the inlet control valve to be quite oily (I may have the wrong name, but a photo is below) and quite a bit of oil below it over the thermostat etc, I gave it a wipe and asked phil to check again after a drive. As this controls the I/C inlet jobby (again, totally forgot the name), if the oil is from something important could this cause any flat spots?
The other thing I found was a "box" wrapped in duck tape and a hose goes from that into the turbo pipes/air pipes. On my car (three door) the same pipe goes off towards the I/C, where on Phils its cable tied on the drivers side under the radiator, totally exposed. I have no idea what it is, see photo below, can anyone advise what the box is?
Another thing we found, was that the boost solenoid valve although seemingly ok, has a botch job done on the lower pipe - essentially some sort of hardened plastic has been used to form around the pipe to keep it fitted to the valve. During tests, the valve appears fine though, but we didn't drive at speed with the laptop tested so unsure if that would make a difference.
