Final operation
Have the laptop ready to go when battery connected.
Ignition on and connect using MES to gearbox.
Run the bleed procedure following instructions on screen and top up reservoir.
Run the robot recalibration procedure. It will clunk away for a couple of minutes and may bring up errors. Don't panic
Disconnect laptop from gearbox.
Ignition off.
Ignition on.
Reconnect laptop to gearbox and clear any errors.
Put gearbox in Manual mode and run it through all the gears.
All Good!
Start engine and test it.
Celebrate with a whiskey.
It will be a bit jerky for a few Kms (miles) until the computer realises the plate has been replaced.
