removing the bumper
there are three 13mm bolts inside the boot, left and right under the rubber grommets and middle exposed. Turn the other bolt heads in the arches right underneath to release the edges of the bumper and carefully disconnect the number plate light wiring.
and you should see this
colours may vary
if your removing the bumper for another job then skip to the end for refitting but its fairly simple as its the reverse of removal.
