Running wire
Your now going to run the wire inline with the adjuster cables. These cables dont move so theres no need to worry about wires getting stripped.
Remove the rubber sleeve so you can see where there wire is going, feed it into the hole, then pull it through, then fed it through the 2nd hole and pull it.
Keep pulling it until you have just enough left to take the wire up and across the support structure. Add more glue to keep the wire in place, then reattach the circular plate with 3 hex screws. Reattach the rubber sleeve.
Next page: Sealing
Previous page: Mounting
