Removing the Instrument Cluster
Start by removing all 3 allen bolts on the underside of the steering column (2 up front and 1 further down)
Then unclip the plastic cover from the top part and pull away.
Once this is done you will probably need to turn upside down to see the other 2 bolts. You will probably need a torch to see these bolts. You can then remove the top plastic cover.
Move the material out of the way until you see the 2 bolts holding down the cluster.
Remove these and then remove the 2 visible bolts at the top part of the cluster.
You can then pull out the loose bit of plastic to get proper access to the cluster. You then need to pull the cluster out. As soon as you see the wiring loom plug it out and pull the cluster free.
