Technical oil coolers
Edinburgh
info courtesy of j333evo
this is a list of parts used to fit a cooler to a cinq turbo though can also fit a non turbo.infact its easier on a N/A engine as there is more space in the oil filter area.
oil coolers would only really be needed on highly tuned N/A engines and on turbo engines its a must have.
OC1193 - 8 Oil Cooler 19Row 1/2BSP Male £64.71
OTSP1M Thermostatic sandwich plate 1/2BSP £33.44
626 Extension Screw M20 X 1.5 (make sure you get this as they sent me the wrong one at first and it didn't fit the screw from the oil filter comes off, tho I believe they have updated the system now to acknowledge the Cinq)
BRKT1 pair of cooler brackets (not used) £ 2.94
For anyone who has seen my car the cooler is situated in the far right corner of the car when looking at it, to achieve this I used;
HEFSW3 - 8 1/2BSP FML ST 1/2" Hose swaged 2@ £ 2.33
HEFSW93 - 8 1/2BSP FML 90 1/2" hose swaged 2@ £3.03
S100R6 - 8 Stainless 100R6 hose 1/2" ID 1.73M @ £9.36per/M
hoses @ 80 & 93cm ST/90 = £14.47
Less 10% to all items
UPS standard service £8.95
Total £124.17
VAT £21.73
this lot came to £145.90 which included postage at £10 but I did get a %10 discount as which is shown on my invoice on every item just because the guy on the phone thought it was to dear! so I would phone to order rather than use internet as you may get same service.
http://www.thinkauto.com/ otherwise know as MOCAL.
in the picture below you can see the oil cooler on the far right.
centre is the intercooler and left the radiator
