Technical overheating
Edinburgh
As with virtually any car, Centos can suffer with overheating, but our little cars run quite hot anyway - it's normal for the cooling fan to cut in and out every 30 seconds or so when stuck in queue traffic. Here are a few possible causes.
Loss of pressure in cooling system - the water needs to be pressurised to raise its boiling point, otherwise localised boiling can occur inside the water passages - this can be caused by leaks or a faulty expansion bottle cap (£3 from Halfords).
radiators don't last too long, average 4 years or less.
they are positioned in such a way that they get all the spray and much thrown at them whilst driving.
you can have the tiniest of pin holes which can be really difficult to locate
If the little cooling fins are rotten or missing on the radiator, the efficiency will be greatly reduced and can also contribute to overheating.
Electrical failure
The fan switch or fan itself can fail, robbing your car of that extra air flow over the radiator.
Muck! It could be in need of a radiator flush.
Failed thermostat - about £12 each, when they go they can stick open (at least you'd still be able to drive home) or closed (it'll boil over).
also see the forum posts on modded 82 degree thermostats
The Dreaded Head Gasket - see other FAQ
Excessively low oil or water levels. (e.g. way under the min mark)
sticking/dragging brakes - as the engine has to push harder to reach speed then this can lead to strain/overheating
finally if the car has overheating issues then sort it sooner rather than later.
a small leak for example is a lot cheaper to fix than a blown headgasket!
thanks to pete(fixitagaintommorow) for the info :)
