f1ian
Hi All.
I'm hoping the collective knowledge here may be able to help me.
This morning on a drive all was OK with my Seicento Sporting. This afternoon - not so much!
The high temp light came on, pulling over and popping the bonnet I was met with a violently bubbling expansion tank, steam pouring out everywhere etc.
I let it cool down, looked inside the tank - empty - stole some water for the drive home (another boil over and wait on the way) and had a look
No obvious sign of water on the dipstick / oil filler hole / exhaust pipe tip / no oil in the radiator expansion tank, squeezing the top hose made gurgling sounds and signs of movement in the tank. The engine runs fine - no mis-fires or lack of power etc. There are no horrible sounds coming from anywhere and alternator is charging fine and its belt is still on.
After a full cool down to cold, top up to max and test drive it boiled after approx. 2kms. Waiting for a cool down and complete the journey had emptied the tank again. (engine still running fine apart from the obvious...)
I'm thinking that it must be the water pump that's given up but maybe someone can advise - I have mainly air-cooled cars in the past and never actually changed a water pump - what exactly fails??? I have no water loss from underneath as far as I can see, the amount of water loss must be from boiling/spraying it everywhere - no way it could still run normally if it was a head gasket
One thing - revving the engine shows no water movement in the tank (hot engine) I would have expected so see bubbles or something.
I would appreciate any advice to get me back on the road - I'm thinking of ordering a pump and thermostat housing to be safe - Its going to be a bit tricky job given that currently I can't pop out to get bits with the lockdown and all so any advice of what to get as an order would be very greatly received.
Many thanks
Ian
Many thanks
Ian
