cinq power
- Oct 14, 2011
- 3
- 2
I bought a BMC CDA filter the other day for £35 off ebay which is a bit of a bargain I think! Instead of using the 899cc bob or silicon hosing im going to design and make a custom airbox. Its going to be based on the 899c bob but with a larger intake pipe to match the size of the BMC intake. Im doing it this way so that I can plumb in the breather pipe and the other thing which is inside the standard airbox. There will then be a section of tubing from the filter down to a trumpet which I will mount in the bumper next to the towing hook.
So today I test fitted an 899cc bob to get an idea of dimensions, and sizes that tubing is going to have to be. Its just a test fitting so its all bodged on for now. For example gaffa tape is currently securing the airbox to the filter and also to hold the breather pipe into a hole I drilled in the side.
Im planning on replacing the cardboard covering the coilpack with some sheet steel so im going to put a couple of mounts on there to secure the filter too.
