Okay so you’re looking at a seicento
The update for the cinquecento it has basically the same mechanicals but with a different bodyshell/interior.
the sei is considered a little more refined thean the cinq.
There’s no Haynes available so buy a cinq one as it covers most spanner jobs.
The sei was introduced in 1998 with the crossover plate with the cinq being an S plate.
on release there were 3 models to choose from:
The S and SX use the 899cc overhead valve engine
The sporting uses the 1108cc overheadcam engine.
prices from new were roughly
the 'S' as with the cinq is the basic model however some equipment leves have improved but some have dropped.
standard equipment included:
the 'SX' has slightly more standard trim levels:
the sporting has more again:
here you can check what a car failed/had advisories on its last MOT
handy to see what should/could have been done and a haggling point
okay things to look out for:
- sporting £6,835
- Michael Schumacher Sporting £7,939
- sx £6,809
- sx £6,252 (1.1l engine)
- s £6,510
- s £5,980 (1.1l engine)
- citymatic £7,109
- Mia £5,985
- Mia £5,534 (1.1l engine)
- 2 tone £6,238
- active £6,085
- active sport £6,385
- suite £7,019
- sound £6,484
- Cat 2 immobiliser
- Halogen Headlamps
- Third Brake Light
- Carpeted Boot
- Front Seat Belt Pre-tensioners
- Electronic Headlamp Adjustment
- Energy Absorbing Steering Wheel
- Analog Clock
- however no wheel trims or tinted glass are fitted as there was on the cinq 'S'
- Top speed - 87mph
- BHP - 39
- Acceleration from 0-62mph - 18secs
- Maximum torque - 48lbs per ft
- Combined fuel consumption - 46.3mpg
- 4 Speed Heater Fan
- Body Coloured Door Mirrors
- wheel trims
- tinted glass
- (performance as 'S')
- Sports Bumpers
- Front Fog Lights
- Decorative Side Strips
- Aluminium Accelerator Pedal
- CD Player
- however the sporting now has no water temperature gauge compared to the cinq
- Top speed - 93mph
- BHP - 54
- Acceleration from 0-62mph - 13.8secs
- Maximum torque - 63lbs per ft
- Combined fuel consumption - 45.6mpg
- optional equiment included ABS and electric(EPAS) power steering
- later the citymatic was introduced:
- this was fitted with the 899cc engine but used a power clutch on a manual gearbox.
- so to change gear you just ease off the power and change with no clutch pedal used(none fitted)
- the citymatic system has proved unreliable and wasnt kept in the range for long.
- repairs can be expensive though its not too much work to convert them to full manual
- the citymatic is equipped as per the 'SX' with the addition of power steering
- in 2001 the sei range was updated:
- all models now use the 1108cc engine.
- this has been updated with multipoint injection.
- power output remains @ 54bhp
- some other updates were:
- larger headlamps
- clear front and side repeaters
- different wheel trims
- new style Fiat badge
- different seat fabrics and headrests
- opening rear quarter-lights
- digital mileometer
- power steering
- the 'S' equipment stays the same bar the above standard updates
- the 'SX' has electric windows,bodycoloured bumpers and central locking
- the 'sporting' whilst fitted with the same engine as the other models is still faster due to its close ratio gears.
- it also has:
- 13" alloy wheels
- aluminium effect dashboard
- sports bumpers
- sports seats
- leather steering wheel and gearknob
- lower suspension
- also available was the Abarth model,over the sporting it had:
- side skirts
- tailgate spoiler
- 14" alloy wheels
- Abarth lettering on the front bumper mesh(MPI engined abarths only)
- later to celebrate formula 1 success a limited edition michael schumacher edition was released.
- this was an abarth in red or yellow with michael schumacher decals(MS) and keyring
- In 2002 a 2-tone limited edition was also released, the colours included light/dark blue, grey/orange, dark/light grey.
- In early 2003 Active, Mia and Sound where released, these effectively where the S and SX re-branded and improved. In late 2003 the Active Sport was added. Late 2003 saw the end of the Schumacher.
- there was also a 'suite' edition fitted with air conditioning
- paint fading/mismatch: some colours fade owrse than others.
- red is probably the worst and polish is only a temporary fix asd it will show again.
- mismatched panel colours are often an indication of accident repair.
- corrosion.the seis are galvanised so rusty wings for example are usually as sign of pattern parts replacing fiat parts through accident.
- thats not to say you wont get rust.
- check inside the boot for corrosion,around the windscreen,wheel aches and chassis.
- leaks:check in the boot as rear lights seals are known to leak.if iftted check the sunroof is not leaking
- red/blue keys: from 1998 to 2000(approx) the sei has the same keys set up as the cinq.
- so if you have this set up your car should have 2 blue keys and one red key(unless its a very early cinq)
- the red key should not be used but kept to code new keys.
- there are ways around this if the red key is missing but it makes a great haggleing tool.also make sure the red keys starts the car and isnt a fake put there to stop haggleing
- if you have ther later type of immobiliser keys. No separate red Master key supplied, just 2 ignition keys with built in chip.
- If the key has a transponder sign on it (Triangle with 2 little rings around the top) then it needs a master key. If it has a 2 on it, its a 2nd generation one and doesnt. If it has nothing then you dont need one either.
- locks:check all the locks work with all the keys inc the locking petrol cap.a non locking cap is an MOT fail so check it.
- also if the car has locking wheel bolts check you have a key,it fits and none of the bolts are chewed up!
- electrics:make sure all the electrics work inc rear wiper,front washers,horn,windows etc
- petrol tank:its a known issue that was subject to a recall that tanks leak at the seams.
- so check for leaks especially if the tank is low on petrol as this may be to cover the leak
- overheating: make sure the car warms up and that the cooling fan comes on and goes off.
- check it doesnt over heat in traffic/standing and dont just think because it doesnt overheat on a constant test drive that its fine.
- make sure you get hot air out of the vent in the car(good time to check the heater works on all speeds)
- check the oil for mayo and the coolant for any oil.
- check the radiator for obvious leaks & corrosion.
- same goes for the rest of the cooling system.
- service history:its always good to get a car with service history but the earlier seis are getting long in the tooth so general condition is often a good indicator of the care its received.
- flatspots:from cold the spi seis can have a flatspot in acceleration around 2000rpm
- handbrakes: the cento handbrake isnt great but make sure it holds the car and isnt binding
- rear suspension: listen for any knocks and thumps from worn rear bushes
- washer fluid bottle: check for leaks as the pipes are known to perish and leak
- mileage: now this is a tricky one.on the one hand you get uncared for low mileage 'city' cars that never get to stretch there legs. or you get worn out sky high mileage ones.
- so a little common sense is needed here.
