Due to the fact that there seems to be a huge amount of repitition of threads in this section, i thought an appropriate guide that we could link members to giving a basic guide to taking care of your car would be useful.
This guide is nowhere near definitive, but it's certainly a good starting point.
Basic Steps:
1. Wheels
2. Snow Foam
3. Shampoo
4. Drying
5. Claying
6. Polish
7. Wax
1. Wheels
Wheels are usually the first step for me. A highly recomended product for these is Bilberry Wheel cleaner, it is a concentrated cleaner which you should dilute in a spray bottle.
No doubt your wheels are in a state like this:
i) spray on wheel cleaner
ii) leave to dwell for a few minutes
iii) either spray again and aggitate with a wheel brush or
iv) jet wash off
This should leave your wheels looking somewhat better like this:
You can at this point, clay your wheels and apply a wheel sealant or wax, or just leave them be.
2. Snow Foam
Snow Foam is a must if you want to limit the contact you have with the car (thus help reduce wash marks) and want to keep your paintwork in as good condition as possible. For snow foam, you will require a Pressure Washer, a foam lance and snow foam. You then need to calculate the dilution of the snow foam solution for your lance.
Your car is probably looking something like this at the moment:
i) spray on snow foam
ii) leave to dwell for 5 minutes (ish)
iii) pressure wash off starting low down and ensuring you are not pointing the lance at 90 degrees to the paintwork.
iv) your car should look semi- clean after this, as the foam frees up contaminants and dirt on the surface of the paintwork.
3. Shampoo
Its time for the most obvious step now- shampoo-ing the car. There are lots of different shampoos out there, and your choice should depend on what type of finish you want. Use a wash wax solution if you do not intend on waxing the car yourself, or choose a shampoo if you do such as Dodo Juice born to be mild. You will also require a wash mitt such as the Meguiars Lambswool mitt.
i) dilute shampoo into a bucket of warm water (nice for your hands)
ii) fill a second bucket with just water
iii) dip your wash mitt into the shampoo bucket and wipe over a panel on your car
iv) after a panel, dip the washmitt into the bucket with just water, and then refill in the shampoo bucket.
v) repeat steps iii & iv starting high on your car and working lower and lower until the whole car has been done.
vi) rinse off the car with free flowing water (ie not through your pressure washer)
You should now be left with a pretty clean looking car. Heres one i did earlier:
4. Drying
To dry your car, you are going to require some microfibre cloths (or one big drying towel fit for purpose) and a drying lubricant such as dodo juice time to dry. I personally just use Meguiars last touch as it is dilutable and cheap, but it does effect the life of your drying towel due to lowering their solubility properties.
i) spray the car with your chosen lubricant
ii) If you are using a drying towel- fold it into quarters, and continue to dry a panel until that side is full saturated with water, then turn over and use another side.
iii) dry the entire car from top to bottom
iv) admire your clean dry car
Easy Step huh?
5. Claying
Getting onto more 'specialist' stuff now. To clay your car, you will need some auto clay such as Bilt Hamber Soft. Sonus Fine is also recomended and good value, but requires a lubricant such as Meguiars Last Touch.
This is a good video on how to clay your car:
basic steps for claying:
i) clean your car- see previous steps
ii) knead clay until it is maleable
iii) mist on the lubricant (for Bilt Hamber clay you only need water!)
iv) rub clay on bodywork until it is completely smooth, kneading to a clean surface when required
v) re-wash the car.
vi) seal the paintwork
Try not to clay the car in direct sunlight or on a hot surface, and remember that paintwork needs to be sealed after claying, dont just leave it.
6. Polishing
Polishing is very useful for removing light marring / swirls to the paintwork, but the best results can only be achieved by machine polishing. Possibly the best polish out there is AutoGlym Super Resin Polish (shop around, can be as cheap as £10/ litre). It has a slight abrasive cut and uses fillers to improve your paintwork. You will also need an applicator pad, and some microfibre cloths to buff it off.
i) clean your car / clay if required
ii) apply SRP to the paintwork in small amounts using the foam applicator and work until clear- less really is more with this product. If you are experiancing a lot of dusting then you are using too much.
iii) buff off using microfibre cloth.
iv) repeat until desired gloss is achieved.
If you dont want to wax but have clayed your car, it is fine to just put a layer of SRP on top.
7. Wax
There are many different waxes on the market, some ultra-expensive. Collinite is a budget priced wax that is considered very good value for money as it beads very well and lasts over 6 months. To apply wax, you will need a foam applicator, and some microfibres to buff off (see above).
i) clean, clay and polish the car
ii) apply a tiny amount of water to foam applicator
iii) apply wax sparingly to paintwork
iv) decide on a cure time (for collinite no more than 10mins as it becomes hard to remove). This is basically how long to leave the wax on the car before buffing off.
v) buff off with a microfibre cloth
It is a good idea to mask off any black trim on your bodywork to prevent getting wax on them as it can be a pain to get off afterwards.
This is basically it, after this, your car could look as good as these:
sure you dont mind Matt and Andy.
Thanks for looking
All products also available from other suppliers
Basic Steps:
1. Wheels
2. Snow Foam
3. Shampoo
4. Drying
5. Claying
6. Polish
7. Wax
1. Wheels
iv) jet wash off
2. Snow Foam
3. Shampoo
4. Drying
Easy Step huh?
5. Claying
v) re-wash the car.
6. Polishing
7. Wax
Thanks for looking
