ok, iirc the offset is 30-40 for a bravo. is this right.
the pcd os 4x98, i know that.
can you get away with 4x100 and wobbly bolts#? has anoyne used these? i dont understand how they work, but are they safe to use etc. anyone who has/ or used them can you comment please.
and what is the center bore? iirc my old corsa was 56.6 what is a bravo?
and finally there are two pins sticking out of the hubs where you would mount the wheels. if i for instance tried to put aftermarket wheels on, the pins would just get in the way, and i wouldnt be able to do it.
can you only buy certain types of wheel that fit round the pins??
