El cargador
Member
To all you experienced people in 500's can anyone explain how the centrifugal oil filter works.does it need maintenance? as i have the engine out would it be wise to fiddle with it?
It's been discussed before here and elsewhere.
https://www.fiatforum.com/500-classic/422661-oil-filter-clean.html
http://fiat500club.org.uk/chat/viewtopic.php?f=4&t=5223
I have cracked the centrifugal oil cover on my 1970 124 spider 1438 as the bolts on the cover don’t line up well with the pulley. I am going to get another one but do you know if this cover only goes on one way? Also is it possible to eliminate the centrifugal oil filter and if so how as it has an external oil filter.Before you take the oil-filter cover off, make a note of its position---it has one of the timing-marks on it. If the filter has not been off for a long time the muck in it will be quite hard (and look a bit like the aluminium casing)--it will need scraping out, possibly with a small screwdriver, or similar. My recommendation is that it is done every 12,000 miles, or bi-annually if your mileage is low.![]()
On the 500 and 126 engines, the cover for the centrifugal oil-filter will only fit in one position where all the bolt-holes line up; I wouldn't be surprised if Fiat designed ALL the engines that used this filtering system to be the same (and in the pictures that I have of the Fiat "twink", the cover looks exactly like the 500/126 part---and knowing Fiat, I wouldn't be surprised if it was!). Sorry I can't personally answer the question as to whether you can eliminate the centrifugal filter system and rely entirely on the external filter.I have cracked the centrifugal oil cover on my 1970 124 spider 1438 as the bolts on the cover don’t line up well with the pulley. I am going to get another one but do you know if this cover only goes on one way? Also is it possible to eliminate the centrifugal oil filter and if so how as it has an external oil filter.
