iamwoody10
Hey Guys ..... ohh and Gals
So.... school boy error time, The ignition set has been removed from my car without marking, or at least noting, where everything goes i.e. .... complete distributor was removed, the rotor arm & cap and leads were removed....
I dont have a manual, and was looking for a wee bit help getting it all back together
can anyone please let me know the following.....
1. What cylinder is cylinder 1 ?
2. Which Plug Lead goes where on the Dizzy cap
3. When the distributor shaft/gear engages, roughly where should the rotor arm point
I have found the mark on the crank pulley and i pulled the spark plug out on the cylinder nearest the tailgate to check if its up...
Any help would be gratefully received
