Technical Distributor weights
BarryH
Essex
Hi all, have been tweaking timing over the last couple of weekends on the 500F. Carburettor mixture is showing a nice bunsen blue now at idle. The idle speed seems to be at its happiest around 1000-1100 rpm and the timing at this speed is slightly advanced of 10 deg as per video where I am thinking unleaded fuel may be a factor here with a slower burn. The question is that if I rev the engine the timing doesnt instantly return to the prior timing position immediately. I am running a powerspark module instead of points but I noticed that there was no felt pad on the distributor shaft so thinking that no oil to lubricate the weights which may be sticking. Any thoughts much appreciated. Barry
  • 20250301_102919.mp4
    41.1 MB
Sounds logical to me.
In the old days when points were common, on every service I used to oil the distributor shaft, then work the shaft using the rotor arm to check the balance weights were moving and the shaft hadn't seized.
I also used to oil down towards the balance shafts where possible via any holes in the base plate.
You could usually feel the return springs a little working. I would use engine oil via a squirt can.
Where applicable I would test the vacuum advance side too.
Some electronic ignition systems work from a fixed timing point and have built in advance capabilities, but probably not in your case.
Another point 1000-1100rpm idle sounds high to me so may stop balance weights returning to normal static position, weak balance springs could also be a cause, although note if you examine balance weights and springs there is usually two and one may appear loose compared with the other , but often that is a feature of the advance set up so do not try and shorten it etc.;)
As"Bugsy" commented---1,000 to 1,100 rpm is too high an idle, it should be about 900 rpm, and at those revs, the ignition light will be flickering (that is if you have a dynamo). Your slightly hire idle-speed may indeed be slightly activating the advance bob-weights. New bob-weights and springs are available from one of the continental suppliers (but off-hand, I can't remember who).
Hi Barry,
Random question, what your procedure for mixture setting? Curious how you observe the bunsen blue flame?
Hi Barry,
Many thanks guys, I will take a look at the Distributor internals and dial back the idle speed a little and yes a dynamo
Hi Barry,
Hi with regards the bunsen blue, I followed the helpful comments on many of the posts to turn out the mixture screw 1 -1/2 turns from fully wound in to get me in the ballpark adjusting the idle screw a little as I went and then used a Gunsons Colortune to fine tune. Still some tinkering to go, it feels like spinning plates atm 🤣 timing >> mixture >> idle, I am new to air cooled engines so every days a school day
