Technical Key code immobiliser problem.
domster
I have a Punto ELX 90 P reg which won't start because the key code light is on. I have tried the red key and the two blue keys but the key code light remains on. The engine turns over but won't fire because of the immobiliser. My local garage says I need a new ECU, Ignition Pack and immobiliser with key. Is this correct? Despite a lot of searching I can't find anything for the 1.6l engine of my car only 1.2l, would that do?
I know I should scrap the car but it has been in the family since new and has done under 40k and was a nice little runner before this problem. Should I give up and scap it or can it be saved?
The 1.2 stuff won't do it -- you have a different ECU.
There are companies out there that can rebuild or virginise ECUs. There will be 1.6s out there being broken.
BUT I'd suspect an issue between the chip reader (on the ignition barrel) and the code box -- try tracing the antenna wire (usually looks like the kind of twin core stuff on your Gran's old bedside light) back to the box -- check for breaks, contacts at the end, etc.
If in doubt, a local autoelectrician may offer alternatives that the garage doesn't know about.
Why should you scrap it!!! :eek:
Worst case scenario is changing a few bits from a car being broken, its not massive issue to swap these parts over.
http://www.ebay.co.uk/itm/fiat-punt...arts_Vehicles_CarParts_SM&hash=item3f36ae18ce
But do trace the wires back and check for faulty connections/connectors and the like first.
Thanks Blu73, I have fiddled with wires and connections to no avail. So can I buy your ECU and accessories please.
Also thanks to everyone else for their advice.
Cheers Domster.
Thanks any way, I had a good look on ebay and I couldn't find anything. I hope it does the trick.
how do u make them virgins again?
1.1 petrol, I know this is an old post but im currently having the same issue, couple weeks ago the car couldnt start at all so i made a new key with a completely new code witch the key guy implemented in the immobilizer, now it only partially works, sometimes the key light dissapears and sometimes it doesnt, for example in the morning when i start my car to go to work it works completely fine, but when i turn of the car and try to start again the key light doesnt turn off, and i have to wait some time for it to work again, some local mechanics told me it could be a problem with the crankshaft position sensor so i changed it but it still persists, could it be a problem with the antenna on the steering lock?
I had a very similar issue on my Brava 2000. Turned out to be the antenna that goes from the ignition barrel to the immobilizer box behind the dashboard. The wire got damaged from a previous repair that required that the dashboard be removed. I see you are from the same city as me, send me a DM so I can send you the location of the shop that diagnosed and fixed my issue :)
Have you tried to put the blue key in the ignition and wave or press they red key next to the reader ( I once taped one of my 60sx keys on the immobilizer box and the car started and ran, as I removed the chip that was in the key)
As some cun7 had broke into my car, smashed the ignition lock and tried to steal it.
As above, they had burst the Halo aerial wire. So I soldiered the wire back together.
Maybe give that a try???
Well, that is next on my list, change the antenna, and if it turns out its not that then i might just sell the car for parts,
dont know how to dm tho, im from skopje
Sorry I didn't get any sort of notification that you've messaged me back, I just saw by coincidence. The place where I got it fixed is Fiat Derbi in Ilinden. Wish you all the best.
