Sinneduk
Hello, i just bought the after market keyless entry central locking, my central locking stopped working, i done connect the +12V and -negative also the indicator lights into fuse box all sorted except those white wire for lock and white/black for unlocking can't find it on the fuse box and even the elearn CD disc which i have please help me....
Regards
Dennis
I found it on the Elearn Cd but i don't know which connectors should i connect.. confusing for me those M66,M67
Functional description
The actual lock/release function and the dead lock function are controlled by driver door control unit M66 , passenger door control unit M67 and boot control unit (which manages the rear doors) M63 ; all these are connected via the CAN line to Body Computer
Control units M66 and M67 are supplied- at pin 11 of connector D - from a line protected by fuse F32 of underfacia control unit B2 .
Control unit M63 is supplied - at pin B8 of connector A - from a line protected by fuse F36 of underfacia control unit B2 .
Control units M66 and M67 the following inputs:
lock signals from knobs (or key in lock) at pin 23 of connector B of M66 and M67 pin B4 of connector A and connector B of M63 ;
Dead lock activation or deactivation signals at pins 24 and 25 of connector B of M66 and M67 ;
lock/release button signal located in control unit H44 , at pins 34 and 356 of connector A of M66
the signals coming from the aerial-receiver P93 , which is connected to pins 21 and 31 of connector B of M1 .
Regards
Dennis
