- Nov 10, 2013
- 35
- 7
So after being very happy with my 02 1.6 stilo 3dr my first major problem has crept in.
Symptoms are...
Car keeps cutting out but will start again straight away. Happens at high speeds, low speeds,idling both hot and cold. I plugged in and got p0340 camshaft position sensor fault.
Brought it to fiat and they said it was the Phase sensor. Quoted 700euro to replace it
Said timing belt, waterpump would be replaced in that too. So I assume they have to come off to get to it.
Is this the same as the camshaft sensor then? Other thing is I have had a few ASR Loose connections warning on and off with the stalls. Could it be this famous D4 ECU connection or bad earth doing this? Would really appreciate anybodies thoughts who knows more about this than me.
I got the car as a bargain and managed to get some nice cheap mods on it too. I want to keep it but cant spend that sort of money on 02 car.
Symptoms are...
