I have a problem with the drivers side brake light not working, It is more than likely my fault as I tapped into it to run the trailor lighting, The display says brake light failure and there is no power to the light I have disconected the trailor wire, I am assuming there is a module that splits the brake light signal and is also the bulb checker, The problem is finding any info on where things are. If anyone can help I would be most greatfull
PS I have run the trailor for 9 years so canot complain to much
Thanks Jez
Thanks Jez
